Clutch Question
Old Oct 18, 2004 | 02:00 PM
Bronco2Nic's Avatar
Bronco2Nic
Clutch Question
I'm doing an engine swap and before I put the engine back in I was woundering if I should change all of the clutch parts. I have a new Disk but the pilot bearing, throw-out bearing and the clutch plate are fine. I have heard that you should just change everything but I don't want to spend all that money if I don't need to. Thanks for any help.
Old Oct 18, 2004 | 02:13 PM
85e150's Avatar
85e150
Unless you replaced it all within the last few thousand miles, I'd swap it all out.
