Hard to Start
Hard to Start
At times the engine is hard to start and I hear a relay clicking under the dash on the right side of the steering coloum. If you keep cranking it will finaily start. When the relay stops clicking the engine starts.
I have changed the Glow Plug Relay,and it does seem to be working. The CPS appears to be working as the tack reads above 100 RPM, I have not noticed any smoke after it starts.
I have looked at other post and I belive the problem is with the relay clicking but I don't know what it is.
Hard to Start
I found the problem, it was a loose wire to a relay block under the dash on the right side of the steering column holding three relays. This is the same area that the clicking was coming from. I'm not sure what it is called because the only thing that I can find in the books is I/P relay block, it maybe the fuel pump relay. You have to take the dash apart to get to it. So far it it starting real good.
Thanks for all the help.
