help where did my oil go, engine locked up when truck was not running????????????
1997 ford f 150 4.2 i ran my truck a few days ago and it ran fine, i cut it off and it sat for about a week. i went to start the truck and the engine was locked up. i checked the oil and there was none. no oil on the driveway where did it go and how did it lock up if it was not running......
Originally Posted by BlueOvalFitter
All your questions are answered here;
www.leakingfords.com
Finally, I was right about something
Hm, weird. Gasket failure usually results in anti-freeze/coolant leaking INTO your oil, not your oil leaking INTO your radiator, right?
When was the last time you changed/checked your oil? Did your drain plug fall out and the oil leaked out while you were driving, hence when you parked it there was nothing left to leak out?
Tom
Tom
Don't bother calling ford.
hey, if your capable of that type of engine repair and have the proper tools to change the upper and lower gaskets, then go for it. however, did you ever figure out where your oil went???? Not into the radiator right? I don't think that's possible as the radiator carries much greater pressure than that of your oil.
Tom
Tom
Originally Posted by chipperfan
hey guyes guess what, i removed the number one and two sparkplugs and water poured out of them. hydro locked... i turned the engine by hand and pumped the water out. can i save my motor it is free now. if i flush the engine and put new gaskets in it will it be saved or am i just s.o.l.
I'm new to the forum, was looking for info about locked 4.2s. Mine's a 97 with 180,000 miles. This truck has been well maintained and ran great. 2 weeks ago I parked it at the local airport. When I came back, it was locked. My mechanic says (to my surprise) that there's no oil in the engine.
I doubt Ford will take any responsibility for a truck that's 8 yrs old with high miles, but I'm gonna try.
Highmiles,
Welcome to FTE,
This thread, if you read above, will answer your question to the T.
Ford will kick you out the door if you ask them to pay one cent for your motor, so don't even waste your breath. Find a mechanic that will do it for less money than the dealer and get the gaskets replaced.
you have the infamous www.leakingfords.com problem. I'm sorry
Tom
Welcome to FTE,
Tom
