Turn signal won't latch one way
Hey all,
Just replaced my turn signal cam on 82 Bronc w/tilt. Now I can latch correctly when signalling to the left but will not latch when signalling right. The latch is not broken, it just appears that the cam can't turn far enough to that side to catch.
I have made sure that my rewire job is out of the way of this also.
Any ideas.
Regards.
Any ideas.
Regards.
I just had the same problem. I bought an aftermarket turn signal cam at Schucks. It would only latch one way. What I found was that one of the 2 straight wires on the back of the cam that contacts the brass terminals (the outermost one), was a little too long to allow the cam to fully seat into position. So, with wire cutters, I snipped off about .090 from each end of the wire. I re-installed it and it works fine now.
Mark VII
1997 - 2003 F150
02-10-2008 04:08 PM
