clamp on thermocoupler for EGT
Does anyone else have the clamp on thermocoupler for your EGT gauge? This is the way I went for the ease of installation. My problem is the washer they sent was damaged. I have an exhaust leak and I'm wondering if the washer is sufficient enough to seal the leak or should I use a high temp silicone ontop of the washer? The gauge works fine and it is Pre turbo.
It sounds like a 'salesman', not a technician or mechanic, giving you his advice. I'd trust the words of wisdom from this forum more than a counter 'salesman'. Make a few more calls, perhaps to the pyrometer manufacturer. Or be patient and wait for the correct recommendation from someone on this forum for a replacement part.
Originally Posted by dpwilson
Just got off the phone with a local performance shop, and they said that a piece of cardboard about the same size would work. I asked him wouldn't the heat catch the cardboard on fire? He said they have done it several times. Does this sound crazy to anyone else?
Ed Willmott
13
03-18-2006 07:46 PM
rmills34
13
01-02-2004 07:55 AM
