Frame changes
Old Oct 14, 2004 | 05:24 PM
1984F15016's Avatar
1984F15016
Frame changes
I was am looking to replace a rotted cross member on a 1984 F 150, but every one i have seen so far from that year has been rotted. My question is, wa sthere a frame change after 1986, or 1992? I was hopping to find one off of a 96 truck if i could.
Old Oct 14, 2004 | 05:43 PM
dynamic's Avatar
dynamic
what crossmember are you looking for ...
Old Oct 14, 2004 | 05:52 PM
bremen242's Avatar
bremen242
I assume you are referring to the crossmember that holds up the gas tank, right?
96's will fit, and F250/350s upto 97 have the same ones as well.
Old Oct 15, 2004 | 02:34 PM
1984F15016's Avatar
1984F15016
the one i want is the one behind the crossmember the cab mounts to. Yes, it holds the front gas tank
Old Oct 16, 2004 | 12:56 AM
mustange70's Avatar
mustange70
80 to 96 (and 96-97 250's/350's) have the same frames.
