Engine,trans. swap?
Nice truck.
Question: how is the engine mounted in the chassis. Was it installed using an FE/FT bellhousing with 'ears' that mount to the frame of the truck?
If so, I would recommend getting a FE/FT automatic transmission bellhousing and installing the FMX iron three speed automatic transmission.
I run a 351C (300 hp) with an FMX tranny and really love it. The tranny is very strong and when I had it rebuilt, the guy said that they are also pretty reliable. The C6 is stronger, but might be more than you'll ever need with either motor.
If you're building a cruiser, the deciding factor may well be the tranny mounting that PC talked about.
67 FE Fan
11-14-2014 04:44 PM
Becky_is_a_66
06-09-2013 01:06 AM
joelburn
09-01-2007 10:07 AM
