Ever seen these rods?
Old Oct 13, 2004 | 01:17 PM
EgoMan's Avatar
EgoMan
I found these on Ebay they look good and there a hell of alot cheaper than the eagles($400 cheaper). Question is you think they would be good?
http://cgi.ebay.com/ebaymotors/ws/eB...926872405&rd=1
Old Oct 13, 2004 | 05:32 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
The ebay link is not working. Anyway there are two types of chinese rods. Those cast in china and finished in the USA which are fine in most cases and the rods that are cast and machined offshore are the problems. The problem is they are not torqued to proper specs when machined offshore causing a out of roundness on the large journal end when torqued to proper specs. They need to be resized before they will work properly. There have been many discussions on the FE forums about these. So if there cheap there is a reason. So ask before you buy....G.
Old Oct 13, 2004 | 05:34 PM
gtex's Avatar
gtex
click on the link, when it doesn't open go to the address line and delete everything prior to the second "http"
The FTE server is trying to tag the address so that you're stilnn looking at it through FTE...ebay doesn't like it.
Old Oct 13, 2004 | 05:37 PM
gtex's Avatar
gtex
BTW , it's a "no reserve" auction, starting at the "buy it now" price...Woohoo...$360.
Old Oct 13, 2004 | 06:58 PM
baddad457's Avatar
baddad457
Why buy chinese when you could have original 427 Lemans rods for less ?
Old Oct 13, 2004 | 07:15 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Baddad, I see your point. Some are leary of 40+ year old rods. Myself I'd run nothing else but old iron as I do. I've had good service with my Lemans rods despite problems some have. Some guys prefer the C3 and C7 rods with bigger bolts over the Lemans. The OEM trilobe capscews and rod dowels are the culprit in most cases. G.
Old Oct 13, 2004 | 08:14 PM
EgoMan's Avatar
EgoMan
And why exactly are they Chinese rods? "The Mustang Depot" TMD right. They look just like eagle rods.
But io know what you mean.
Old Oct 14, 2004 | 03:04 AM
baddad457's Avatar
baddad457
Well I've ogt a set of low mileage Lemans rods if he's interested, they just need glassbeading, shot peening. and new bolts to be ready to go.
scottmotorsports
Jan 13, 2008 10:48 PM
bigredtruck
Apr 9, 2005 09:52 PM
debestuss
Nov 8, 2004 09:35 AM
GolferSA
Sep 23, 2004 07:12 PM
gwcrutch
Aug 27, 2004 08:40 PM
