Are all heads for the 460 Universal? Atleast for EFI? I have a 91 460 with stock heads, and heard someone say that 93 and up had the best heads? Would these bolt right on?
Yes they should, best I recall the differance is the valve size and the exhaust ports including manifolds. newer had bigger valves. Carb heads and EFI heads do not play well together. Intake angle is differant.
