01 Psd Dies While Driving
Old Oct 12, 2004 | 09:19 AM
totavikid's Avatar
totavikid
HELP,my 2001 psd dies while driving down the highway around 100 miles. It's done this several times. I have had it in different shops and they can't seem to pinpoint the problem. Codes are different every time. It has not done this while in the shop and it has been there a few times. I was going to use the superchip micro tuner to read the codes immediately after it does this and see what the computer is saying. any thoughts?
Old Oct 12, 2004 | 09:33 AM
wlihntr's Avatar
wlihntr
thats what my truck did when the CMP(cam position sensor) went out. its a fairly common failure on the 7.3
Old Oct 12, 2004 | 10:07 AM
99PSDCREW's Avatar
99PSDCREW
Be sure to get it from International vice the Ford Stealership.
Old Oct 12, 2004 | 10:28 AM
totavikid's Avatar
totavikid
I agree, the cam sensor is common to failure but it is also easy to diagnose, but that's not the problem.any other thoughts?
Old Oct 12, 2004 | 11:21 AM
Powerstroke2000's Avatar
Powerstroke2000
Lately, there has been a rash of incidents where rain water has gotten into the IDM (injector drive module) creating havoc for a few guys. This is always a possibility!
Another few have had trouble with having a good connection to the ICP (injector control pressure sensor) so you could check the wires in this location as well.
Cam position sensor would be the most obvious though, but it sounds like you've eliminated it in some way? It has been known for a new CPS to be bad as well though!
Ever had your valve covers off? Sometimes a burned connector to an injector or two in the valve cover gasket..or one of the connections has been known to create havoc as well.
Many of us have had issues with the fuel heater as well, and now run with them unhooked, as they are basically only needed in extreme cold situations.
Also, fuel pumps have been known to cause issues.
Check these out, and report back.
Dale
Old Oct 13, 2004 | 06:10 PM
broke 350's Avatar
broke 350
my 01 sd 7.3 did the same thing, took the dealer 3 weeks to find out it was the computer control
