Sponsored by: Real Truck
trans fluid capacity
Old Oct 11, 2004 | 05:54 PM
crewsaV10's Avatar
crewsaV10
hey guys
does anyone know how many quarts of tranny fluid you need to refill if you are just draining the drain plug ?
thanks
02 f250 4r100 trans
Old Oct 11, 2004 | 05:55 PM
wlihntr's Avatar
wlihntr
7-8 quarts
Old Oct 12, 2004 | 04:44 AM
V10man's Avatar
V10man
Yours should also have a drain plug on the tq converter. If it does, drain it too. You'll need about 14qts if you do. You'll get out all but 1-2 qts. Good enough. *remove the 1 1/2" rubber plug from the bell housing to see if you have a plug. You'll need to rotate the tq converter. I bump the starter a cpl times*
Old Oct 14, 2004 | 09:37 PM
crewsaV10's Avatar
crewsaV10
thanks for the info guys
