49 Pickup transplanted onto late model S10 frame..
on
Chew,
If you are going with this project, there is one other piece of information you might find helpful. As you know the S-10 is a very narrow truck and you will probably have to use wide or reversed wheels with a lot of offset to the outside. It is my understanding that the S-10 4x4 rear end it is about four inches wider than the 2wd S-10 and may be a better fit under under the F-1.
Vern
Vern
LittleRiver
07-03-2017 07:35 AM
Jammer-1
05-29-2017 02:10 PM
