please help with 460 before i sell it
Old 10-11-2004, 09:35 PM
kermit's Avatar
kermit
kermit is offline
not with this starter, but i dont have a donor vehicle to borrow until tomorrow anyway, but yeah, i have tried that in the past and it seems like if i jump it off another car it turns over fine
Old 10-12-2004, 11:12 AM
bigblackbeast's Avatar
bigblackbeast
bigblackbeast is offline
its important to use a second battery and cables and hook them directly to the starter (pos) and block (neg) .make sure all coonections are and surfaces are clean. this must be done when the truck is hot and won't start in the usual manner.if nothing changes then its not in the batt, wiring or solenoid.it could still be a starter problem (take it off and bench test it,if it tests fine then look elsewhere for the problem). some areas to check make sure its not overheating,causing internal engine bind that goes away when it cools.make sure the starter is not binding on the flywheel/ring gear
Old 10-12-2004, 07:57 PM
kermit's Avatar
kermit
kermit is offline
??internal engine bind?? never heard of this, could you elaborate a little bit please, sounds interesting.
Old 10-13-2004, 08:30 PM
fordbeast_80's Avatar
fordbeast_80
fordbeast_80 is offline
How is the cooling system, is everything up to snuff, big blocks can get real warm.
Old 10-13-2004, 08:37 PM
kermit's Avatar
kermit
kermit is offline
yeah, the cooling system seems alright, never seems to get too hot according to the mechanical guage
Old 10-13-2004, 11:18 PM
someday's Avatar
someday
someday is offline
whoops-editing
Old 10-13-2004, 11:19 PM
someday's Avatar
someday
someday is offline
hey, i am having the same problem with my 89 460 auto efi w/headers. the last starter lasted maybe 2 months. when the starter is brand new it works great for about a week or two and then goes slow. i also have a fairly new (2-3 yrs) optima battery that holds charge good,but i havent had it load tested. also, i have not changed the wires, but the resistances were fine. in conclusion, i think the starters from autozone are junk. so for about $180 i ordered a 160 ft-lbs Powermaster starter for a 164 tooth flywheel from summit. hopefully, i will install it soon and let you know how it works out.
Old 10-14-2004, 05:54 AM
bigblackbeast
Exclamation overheating
hi , i was referring to the engine getting very hot and causing the internal parts to expand and bind which sometimes would happen if clearances were tight when and if it was a fairly fresh rebuild(bored out ,oversized pistons,rings).
Old 10-14-2004, 08:28 AM
Stonecoldtx's Avatar
Stonecoldtx
Stonecoldtx is offline
Hi, Kermit--
There are a couple of unusual things you've posted:
" . . . i have the timing set about 10deg, if i get any further back than that it pings like crazy and i cant drive it . . ."
and
" . . . if i advance it to get rid of the ping . . . "
First off, it would seem that instead of setting it "back" as you indicate (which would be retarding the ignition timing), you are actually advancing the timing, because that is usually what aggravates "ping", or increases it.
Secondly--to set the ignition timing correctly, you have to have several things:
1.) The correct idle speed as indicated on the underhood sticker (or shop manual)
2.) The vaccuum advance hose disconnected and plugged so there are no vaccuum leaks
3.) The correct timing marks on the dampener in relation to the position of the camshaft
This third point could be where the problem lies--you may have a dampener that has a slipped outer ring, and you don't have the correct timing marks.
This is the condition you describe:
" . . . most of the time when it is hot, my truck is slow to start, like it has a dead batt . . . "
And this statement especially caught my eye:
" . . . when i crank it gets down to 7-8 volts and goes real slow. if i pull the coil wire off it spins faster . . . "
These conditions are usually indicative of too much initial advance. I would say that is further evidence that the dampener has a slipped outer ring, and the timing marks are not correct.
Furthermore, you said that when you "advance" it (which probably is actually the OPPOSITE--you're most likely retarding the timing), the pinging and starting issues seem to improve, and that would indicate that perhaps your distributor might have some faulty parts in the mechanical and/or vaccuum advance units.
Since you just replaced the timing chain, I would recommend the following:
1.) Pull the timing cover off, and make absolutely sure your timing marks are correct (you may have gotten it off by one tooth, perhaps advanced)
2.) Check the dampener timing marks against a "known-good" dampener, and make sure they line up EXACTLY the same
3.) Have your distributor re-curved, or purchase a rebuilt one, and make sure the vaccuum advance unit is working properly (and make sure it's connected to the correct vaccuum source--I can't remember if it's manifold or ported vaccuum on these engines, so you may need to consult a shop manual)
Once you ensure that those items are correct, it should resolve the issue; if it doesn't, then chances are there are other, internal engine problems that will need to be addressed.
Old 10-14-2004, 08:52 AM
someday's Avatar
someday
someday is offline
i am pretty sure the timing on my truck is dead on because i changed the following: new timing set, distributor, damper(slighty off). the only thing i was concerned about was when setting the timing i could put the light at an angle off to the side or directly over the top which got different timing.
Old 10-14-2004, 09:17 AM
Stonecoldtx
Hi, someday--
Actually, I was posting in reference to Kermit's issues--yours may be entirely different.
Old 10-14-2004, 10:30 AM
someday's Avatar
someday
someday is offline
understood, but i am try to relate to his problem and figure my problem out as well. it seems like we are having the same problem
  #28
Old 10-14-2004, 10:34 AM
Stonecoldtx
Hi, someday--
From what I can gather about your issue, since you have headers, and since you seem to be going through starters, it would seem to me that your problem has to do with heat radiated from the headers.
Headers are well known to have an adverse affect on starters, and so I would bet that you would be best served by installing a starter heat shield, as kjkozak2 suggested to Kermit in a previous post.
Try that when you're installing your new, high-torque starter, and I'd bet that takes care of the issue, once and for all!
  #29
Old 10-14-2004, 12:36 PM
PowerbyFord's Avatar
PowerbyFord
PowerbyFord is offline
I know this sounds silly, but are your plug wires in the right order? I have an 85 F-250 with a 460 and when I changed the plugs and wires, I switched #5 and#6 plugs on the distributor cap accidentally and it ran like you are discribing. Hope this helps a little.......Aaron
  #30
Old 10-14-2004, 06:45 PM
kermit's Avatar
kermit
kermit is offline
well, the only way the timing chain goes on is straight up, i used a stock replacement set, so i know the cam and crank are inline. i set the timing with the vacuum advance plugged, and i dont have a reference for idle, so i have been using 750 rpm. i thought too much advance, but no matter where i set the dist. it seems the same, and i have tried adjusting it as far as it will go each way just to see if there is a difference in crank speed. i get the new batt in a couple of hours and i will see what happens after that and post back here.
thanks
Quick Reply: please help with 460 before i sell it
