99 Explorer O2 Sensor failed
Old 10-06-2004, 11:02 AM
stunod2002's Avatar
stunod2002
stunod2002 is offline
Question 99 Explorer O2 Sensor failed
Hi all..
I have a 99 ford explorer 4D, 4WD V6.
I have a Check engin light on that is reporting code 171 - O2 Sensor - Bank 1 is reading to lean..
Can someone point me to where this is located on the truck? The Bank one leads me to believe that there are more than one and I would rather not drop the $60 more than I need to
Thanks for the help
Old 10-06-2004, 02:17 PM
Pig Pen Jr's Avatar
Pig Pen Jr
Pig Pen Jr is offline
When I replaced the ones on my '99 XLT there were 4. One on the exhaust pipe before the cat and one after the cat on each side. They look like spark-plugs that are screwed into your exhaust system.
Old 10-06-2004, 02:31 PM
stunod2002's Avatar
stunod2002
I just got off hte horn with my local shop.. They told me that Bank 1 is right before the CAT... But I only have 2, not 4
Thanks for the reply.... Appreicate the help
Old 10-08-2004, 07:24 AM
ajguzik's Avatar
ajguzik
ajguzik is offline
# of O2 sensors
I believe that all Explorers thru '99 have 4 sensors. On my '96 with a V6, sensor #1 is located on the passenger side exhaust manifold about halfway between the exhaust header and the converter. Best access is through the wheel well by removing the inner fender skirt. I thought only Rangers with the 2.3L had two sensors?
Old 10-08-2004, 07:31 AM
stunod2002's Avatar
stunod2002
I really have no clue.. I am at this point believing the ford guy, after all he should know
I will find out for sure tomorrow when I get down underneath it and see it for my self..
Old 10-08-2004, 08:01 AM
Pig Pen Jr's Avatar
Pig Pen Jr
He probably has the standard 4.0 and not the 4.0 SOHC. That is the only differance I can see it being.
Old 10-08-2004, 08:27 AM
stunod2002's Avatar
stunod2002
Not sure.. I will have to check
Old 10-09-2004, 11:12 AM
stunod2002's Avatar
stunod2002
I actually have the SOHC 4.0
Old 10-09-2004, 01:22 PM
stunod2002's Avatar
stunod2002
Well There is infact 4 sensors.. I could not find anything that specifically said what Bank #1 was, however the wonderful techs at AutoZone said that it was the driver side.. SoI gave that a shot.. I cleared error code so not its a wait and see..
Hopefully the AutoZone guys know what they are talking about..
Luckilly that sensor wasn't all that bad so I can change it to the other side if needed..
Old 10-09-2004, 10:17 PM
'99 black sport's Avatar
'99 black sport
'99 black sport is offline
I have the ohv standard 4.0, not the sohc.......they all have 4 o2 sensors. banks1 and 2 are before the cats....banks 3 and 4 are after.
wtroger
Modular V8 (4.6L, 5.4L)
10-21-2015 03:01 PM
99powerstrokedF250
08-16-2015 02:51 PM
albtrossca
1997-2006 Expedition & Navigator
04-19-2013 10:45 AM
breeaad
07-10-2012 09:02 AM
Redneck1465
11-04-2009 10:00 AM
Quick Reply: 99 Explorer O2 Sensor failed
