Sponsored by: Real Truck
4 wheel low
Old Oct 7, 2004 | 02:05 AM
egress's Avatar
egress
Exclamation 4 wheel low
I have a 2001 sd 5.4 crew cab and I dont feel any change from when in 4 high to 4 low ( auto hubs and on dash switch) low light works when key is switched on but when you switch to 4 low light will not lite and truck will go in to 4 wheel drive but there feels to be no difference in power and seems to only go in to high
Old Oct 7, 2004 | 02:52 AM
Monsta's Avatar
Monsta
Sit. Stay.
You are stopped and in neutral when you're making the switch to 4LO, right?
Old Oct 7, 2004 | 02:54 AM
dhag911's Avatar
dhag911
right it has to be in neutral and completely stoped even if you have it park it wont work
Old Oct 7, 2004 | 07:57 AM
RIS's Avatar
RIS
I have an 01 5.4L CC 250 with manual T-case & hubs and you know when it is in low. There is a big difference between low & high.
Old Oct 7, 2004 | 01:14 PM
camo4stealth's Avatar
camo4stealth
Check the wiring connections to the little motor that switches the transfer case. Maybe even tap it with a wooden handle, just don't smack it. Turn off the truck and start it back up, going from park to neutral, if an auto. Back up and pull forward a couple of feet and stop, waiting in between. At first, mine took some 'persuasion' to make the shift. Getting back out took the same proceedure. As I used it more, the shifting got better. Good luck.
Old Oct 7, 2004 | 07:12 PM
77hiboyboy's Avatar
77hiboyboy
check the connections, both places. switch and motor/solonoid on the t-case. Happened on my parents 95 explorer. Just cleaned the connections everyplace and it started to work.
Old Oct 7, 2004 | 11:54 PM
crashandburn420's Avatar
crashandburn420
You WILL know when it is switched from four high to low. They are markedly different. HTH
Old Oct 8, 2004 | 02:01 AM
egress's Avatar
egress
Thumbs up rubber hammer worked
thanks guys I checked all the connections and wires and the started it N and switched it to 4 low I heard the servo motor but it was still in high I stopped went back to N tapped motor and then it worked so went and got wife and we cycled it about 10 time and now it seem to work fine guess it was stuck
