400 flywheel
400 flywheel
Continuing with the saga of my rebuild...
I'm trying to locate a 400 manual flywheel for my truck. I swapped out the 351c and my buddy had a 400 manual bell housing, but I need the flywheel for it. I've called the local parts houses and got a lot of no's, same answer with the junkyards. The local speed shop can order me one, but they need either the casting numbers or the diameter, balance, and tooth count for the original, which I don't have. Does anyone have a source for this? I know that the 351c flywheel is roughly 1.5" too small. Also, everyone asks if it was a 11" or 12" clutch.
According to the information I found on the net the stock 400 flywheel had 180 tooth ring gear. Most of the aftermarket flywheels I could find are 176 tooth tho'.
A quick look at Dave's (bubbaF250) page shows a current service part # of E5TZ-6375-H. You might want to check with your local Ford parts dept.
Well, autozone was too good to be true. Turns out that the shipping costs doubled the overall price. I did a little more research and found a guy with a shop and a yard full of Fords. He sold me a flywheel for 50 bucks. While he was getting the flywheel out of his "parts storage" van, I noticed a set of headers still in the original box. I asked if he would be willing to part with them, and he sold them to me for another 50 bucks. The flywheel and headers are in, and the motor turns over great. When I get off of my work rotation, I'm going to go and get it started. Thanks for all of the advice and help so far!!!
16
07-25-2015 10:09 PM
4x4ford33
18
01-24-2014 10:56 AM
78_f150
08-29-2013 11:44 AM
HoustonGuy
07-15-2013 06:12 PM
bigdan1979f-250
09-26-2009 08:58 PM
