How much camper weigh can a 2005 F-250 handle?
I just purchased a 2005 diesel, 4x4, with the camper package, the tow package & the 10,000lb GWVR package. The Ford payload specs for the truck are 2700lbs. You can't buy a camper, fill it with you & supplies and come in under 2700lbs. Is Ford undercutting their payload. Are all the F-250's with campers overloaded. What can the truck actually haul safely? Any comments or thoughts would be appreciated.
Thanks, John Pearson
But you ARE right. Most campers are over weight and these trucks are under rated IMHO.
Since you got the diesel, you're even heavier. You don't say what cab config. you have, but if it's a crew cab, you even have less payload.
So, put air bags on that sucker, and if you don't have adjustable shocks (Rancho 9000) and a anti-sway bar, get those too. The most important change is your tires. Those are the weak link. Make sure they are at least a 3415 lb. "E" rated tire at a minimum. If they're Fireblowns, junk them.
Now if you really want to get a real camper set-up, check the pictures of the tires/wheels in my album. The tires are rated for 4080 lbs. and the wheels for 4500 lbs. They really make for a stable ride.
At least the new '05's come with bigger brakes. That should really help you out.
I have an 83 F250HD. I put the HD Airbags on the truck (skip the lightweight bags)
Always make sure the tires are good (I use BFG AT..3 ply sidewall) and can adjust the ride with the amount of air in the bags. When I purchase an 05 V10 350 the air bags will not be needed. 250, use the airbags
Many years ago we had a Lance 9.5' camper, loaded it up, pulled a 18' boat, never had any problems (but I know I was over weight). Now I think I am wiser.
We have a Pastime 8' camper, wet weight is 1600lbs. load it up, pack the tools, inflate the air bags to 45lbs, and enjoy the back roads. Get the air bags they use on Motorhomes, rated 5000lbs I think. From what I can tell, the difference between the 250/350 is the springs, everything else is basically the same, so by adding the airbags you increase the carrying capacity,... but the payload on the door will not change. Tire inflation is very important. Have fun. A truck & camper is the best!
F250_6_2
2017+ Super Duty
08-17-2017 08:21 AM
SpokaneJim
1999 to 2016 Super Duty
02-09-2010 10:19 AM
