Suspension Lift for a bronco II with a CV joint driveshaft
I have an 86 bronco II with a three inch body lift. I tried to suspension lift it, but I have a CV joint drive shaft and the lift put a bad bind on it, making it pop. I am wondering what kind of options I have to lift it without changing out any major parts.
"Speed equals money how fast do you want to go?"
There's no easy way to say this, but if you're screwed. You need a new U-joint drive shaft in 2 parts. U-joint because, well, no body makes/likes CV shafts that I know of and their so much better. And the 2 parts because that's the only way for the driveline to extend the way it needs to. You can find pre-builts relatively cheap, but that's about your only option.
badazb2
Bronco II
10-15-2004 12:10 PM
