I have a 2 inch Sus. lift on my truck with 33x12.5 wild country mudders, the tires rub horribly at full crank, i was told that i could fix this by putting 3/4 ton spring on the front...... will htis hurt anything if i do so?
by putting on 3/4 ton springs do you mean stock ones? if so you will be losing your lift. if it is the bumper, i wouldn't bother shimming it, i would trim the very small, like 1" long/ 1/2" wide, lip on the inside. it works wonders!
sounds like you need a different off set though.....they are prolly rubbing on the springs!
get an adapter that pushes your front axle forward like 1/2" to an inch! i have seen them somewhere, but i gotta run for now...i will get back to ya tonight
What kind of radius arm bushings do you have? if they are the old rubber one try going with poly it might push it forward just enough. They are only about $10 a peice.
