how much weight can my tailgate hold?
If you have a real fear about the tailgate supporting the weight...
consider taking the tailgate off to run the machine up in there and putting it back on later...
if the machine sticks out over the tailgate... put something under the rear edge of the machine at the end of the bed to lever most of the weight OFF the tailgate...
maybe that will help...
dent
One thing to watch out for is the thin metal on the tailgate. As I pushed my 750 pound Harley into the bed once the rear tire dented the inside wall of the tailgate, not sure about the distribution of weight on the tires but probably had more than half the weight on rear. If you're worried about cosmetics and dents then pull the tailgate off before loading.
What BigF350 says is correct - the tailgate is rated for approximately 500 pounds static load, and if you have a larger machine than that you should probably take the tailgate off before loading it. Also, as frghtr mentioned, the sheet metal in the center of the tailgate is pretty thin - so even if the tailgate can support the load, there's a good chance you'll dent or push in the inside tailgate wall. I seem to dent the tailgate on every truck I've had, usually when I'm throwing hay down into the truck off the hay loft - from experience, a 50 pound bale of hay dropped 10 feet will definitely dent one of these tailgates. My theory is that once you get that first dent over with, then you don't have to worry about it anymore.
LK
LK
I thought the gates were spec'd at only a 200 lb rating or something rediculous. In fact we (here on the forum) commented that it would'nt even support our lard butts for sitting on them according to Ford.
Just remove your gate for loading. My Kubota used to load like that with ramps on my older trucks. Just set the ramps on the bumper after the gate is removed and drive in.
LK
thanks, i will most likely remove the tailgate. Oh, and its a work truck, so i'm not concerned with dents. The machine is a jonsered iron horse, a little tracked vehicle for skidding logs and moving heavy things. It distributes the weight really well, the ground pressure is only like 2psi beneath the thing.
Ok, now where can i get some ramps, am i gonna have to build some?
Cabela's.... link to Cabela's
There are a few different ramps on that page... also, browse around, as other sections have other things, such as an ATV rack for when it extends out over your tailgate.
