Sponsored by: Real Truck
electrical problem
Old Sep 26, 2004 | 05:09 PM
chris hellman's Avatar
chris hellman
Question electrical problem
When I open my doors the following dosen't work;
dome light, headlight on warning beeper, key in ignition warning beeper,
radio keeps working, windows still operate.
Can any one tell me where the relay for the switches in the door latches are?
I know it has something to do with the door latch switches but I cant find it.
Thanks Chris
Old Sep 26, 2004 | 08:31 PM
99f350sd's Avatar
99f350sd
Welcome to FTE..
What year? and truck..Sounds like a fuse. Check under the hood and under the dash.
Old Sep 26, 2004 | 08:40 PM
mikewrt's Avatar
mikewrt
I think the newer trucks use a reed type magnetic switch for the door activation. I'm not quite sure where it is at though. sounds like mabye a wire is loose or the switch is stuck. mabye?? how bout some info on your truck.
Old Sep 27, 2004 | 06:49 AM
350z's Avatar
350z
On the newer trucks,the door switch is in the latch,ive read that spraying wd40 in the latch will fix this problem,tried it on an 03f250 and it worked!
Old Sep 27, 2004 | 07:41 PM
chris hellman
I have checked the fuses their fine. It dosn't mater which door is open, it's like the circut isn't getting interupted when I open the door to let those things come on.
My truck is a 2002 f250 4x4
Old Sep 27, 2004 | 07:43 PM
chris hellman
It's a 2002 f250 4x4. Any help would be great.
Thanks Chris
Old Sep 27, 2004 | 07:56 PM
V10MARS's Avatar
V10MARS
Post
Thanks Chris
If your windows and radio work with the key off you may have a shorted GEM module.
Old Sep 27, 2004 | 11:06 PM
chris hellman
The windows and radio only work for about 10 min. then they go off. I don't thik it is the switch in the door because it dosn't matter which door is open. I think it is in the relay (or somthing like that) where the wiring from both doors meet.
Thanks, I'll keep looking.
03slowbra
Apr 10, 2016 02:41 AM
npccpartsman
Escape & Escape Hybrid
Jun 13, 2010 07:48 PM
ford9009
17
Mar 30, 2007 11:29 AM
JBronco
1978 - 1996 Big Bronco
Feb 7, 2003 04:58 AM
sigboss
Electrical Systems/Wiring
Nov 17, 2001 05:28 PM
