'78 F150 won't bleed to rear brakes
Hi all,
I know I've cross-posted this to the brake forum but I really need an answer quick.
Right before I took three weeks to swap the engine in my '78 a hard rear brake line blew. I left it alone as I knew the truck was going to be laid up for a few weeks. This week I replaced the line and one other, along with a the wheel cylinder at the right rear corner. I tried to bleed the system last night but no fluid will come out at the bleeder screws. I disconnected the line further upstream to see if I had a blockage, and still no fluid. I suspect nothing is getting past the proportioning valve.
According to the Haynes manual the proportioning valve should reset itself with a gentle application of the brakes after bleeding...but I can't bleed it. Can the rod inside the proportioning valve get stuck and close off the rear brake system, preventing any fluid from getting past?
There was no blockage when the line blew as great quantities of brake fluid drained out of the bad line, and the master cylinder would empty the side that serves the rear brakes even if I refilled. Now when I filled it to bleed the system, no fluid left the MC.
How can I reset the proportioning valve to allow fluid past?
Thanks,
Tim
'78 F-150 Ranger
Thanks,
Tim
'78 F-150 Ranger
s.squared-39
12-05-2016 04:46 PM
dracond
05-22-2016 07:15 PM
jonmammenga
19
08-17-2015 05:05 PM
HardFordCore
02-21-2006 11:25 PM
nebechanezer
04-14-2005 08:01 PM
