1979 359 v8 is all I know
Old 09-22-2004, 05:41 PM
Dads79350's Avatar
Dads79350
Dads79350 is offline
Hello All,
My name is Matthew and I can tell you what color it is but that is bout it.
My Father died in April and I went to Yuma Az to clean out his apt and all that.
This truck is all he was able to leave me and so I am kinda attatched to it.
I have been living in it since the spring and a month ago it went down.
It has run strong for me,the only problem I had was the key not starting it and someone showed me how to jump it underneath.
A month ago I was driving from Grass Valley to Nevada City Ca when the temp went up and I was losing power. Temp has NEVER gone up.
Last week I checked the sparkplug wires and found one loose. I pulled and cleaned all the plugs (yeah...they were black...one so fouled from the loose wire) put a charge to the battery and dripped some gas in the carb and she started right up.
I let it set (to charge the battery) and then went to drive it up the driveway...and she stalled ... rolled back down jumped it again and same thing... hot hot hot and when I went up hill it cut out and stalled.
I really need to get this truck on the road to either sell or use. I am out in the boondocks and dont have the ca$h to just send it to someone. Any feedback would be greatly appreciated.
If your response requires more info, please tell me what that info is and how to find it.(kinda a neanderthal when it comes to autos)
May blessings find all of you,
Matthew
Old 09-22-2004, 06:06 PM
84-250's Avatar
84-250
84-250 is offline
you dont have a 359ci engine, a 79 came with a 351m. first thing i would do is rebuild the carb or at least tune it so your plugs arent covered in soot. check the idle too. second you need a new key cylinder so you can start the thing.
you have a great truck there, dont sell it
Old 09-22-2004, 07:02 PM
ohms's Avatar
ohms
ohms is offline
Therm
You may want to check / change the thermostat. They're cheap (just got one in stainless for $6.00). If your overheating that fast, it may be stuck.
Old 09-22-2004, 07:05 PM
76supercab2's Avatar
76supercab2
76supercab2 is offline
Check the radiator fluid level. Do it when the engine is cold.
Old 09-22-2004, 07:14 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Possibly a weak fuel pump too if the carb is ok. You may try a new fuel filter as well.
Old 09-26-2004, 11:33 AM
bhawkin2's Avatar
bhawkin2
bhawkin2 is offline
My 79 f250 was doing the same thing changed the fuel filter an thermostat an it was good to go.
nevrenufhp
N. California Chapter
123
10-03-2011 08:23 AM
kennethtyler
09-22-2010 04:34 PM
WoomaHodal
01-14-2005 09:37 PM
matthews_56
Bronco II
04-11-2003 07:16 PM
Quick Reply: 1979 359 v8 is all I know
