runs bad
Old Sep 24, 2004 | 11:35 AM
mike L's Avatar
mike L
New fuel pump bad??
Is it possible that my new external fuel pump is bad? How can i test the fuel pump? Do i need to test the pressure to see if its bad?
Old Sep 24, 2004 | 11:55 AM
pfogle's Avatar
pfogle
Okay. You said it's running rich, indicated by soot on the rag. This is pure hell on the o2 sensor so it probably needs replaced. I would check the fuel pressure and make sure it's within spec (40 to 45psi).
Old Sep 24, 2004 | 07:08 PM
Talyn's Avatar
Talyn
TPS could be jacked up too.
And the Idle air controller.
Old Sep 27, 2004 | 03:21 AM
Jmackenroth's Avatar
Jmackenroth
my 5.0 seems to be having the same problem, only I just tuned it up today, and now its running rougher than before and its shaking while I drive down the road. I pulled codes and it said EGR and o2, but my step dad says they could be old codes. should I check the fuel pressure regulator? Also will gapping them at .045 instead .044 make a difference? our gapper didnt have the .044. Should I try changing the oil too?
Old Sep 27, 2004 | 10:29 AM
mike L's Avatar
mike L
Reset codes??
I think if you remove the ground off the battery for ten minutes that resets the codes. Try for codes again. Did you replace the O2 and egr? Is that why he think its old codes? Somtimes when you change electrical parts it runs bad for a while, thats why you should reset the codes. You should test these two parts with a volt meter first you could have a bad wire going to them.. How many miles on the O2 sensor? I think the manual says 80,000 miles before replacing. Just my 2 cents Did you read the codes yourself?
Old Sep 27, 2004 | 10:42 AM
mike L's Avatar
mike L
Originally Posted by 90f150moneypit
Pull the throttle body off and clean it thoroughly too.
Since cleaning the IAC allowed it to run for a longer period but still acting up, I would guess it's no good. More often than not if cleaning the IAC results in positive results it's time to replace it. Even if it were to completely fix the problem, a short time later they fail anyway but at least you would know that the problem is from the IAC.
They aren't cheap but I would spring for it if it were me, but I would also get that TB off and cleaned good (paying close attention to the air passage and EGR port).
How much does a throttle body cleaning kits clean? It includes something you add to the gas, spray for intake. Thanks just woundering
Old Sep 27, 2004 | 10:43 AM
ssn randy's Avatar
ssn randy
Originally Posted by mike L
Thanks, will do. I have a 1" tube that runs along the straight six head. It looks like its metal and moldeled to the head. It has six 1/4" tubes coming straight up from the side of the head. Right across from the spark plugs. Right at the head it has a small fuel leak, still wet after a few hours. It has a 1" size rubber hose at each end and the other end that runs back about the injectors is hollow. What it this part, why is there a small fuel leak, must be coming up from the head?
What are some thing that would make my truck run rich? Cleaned the plugs and the after 10 minutes of running, it had had black dry sooty ....? carbon? on all of them. Thanks again
are you talking about the fuel rail, tube supplies fuel to injectors, leaking injector may cause this. to check it, pull the wire and read between the two leads on the injector, should be 2.5v, check your manual for this test and correct voltages, but i think if less than 1.8v its bad
Old Sep 27, 2004 | 10:57 AM
90f150moneypit's Avatar
90f150moneypit
Your not looking for a kit. Your looking for a can of TB cleaner just like carb cleaner. The cleaners that go in the tank or through the rail do not reach the TB. Air is the only thing that the TB controls (besides the TPS signal).
You need to pull it off and take the TPS off and spray it real good and use a tooth brush. Make sure the EGR port,air passages and the back of the throttle plates are clean.
And as mentioned - the injectors could still be leaking.
Old Sep 27, 2004 | 12:16 PM
mike L's Avatar
mike L
No there no fuel in it, its 1" thick and hollow, with 1/4" vent holes above each injector, about 1 " away not touching. Its not connected to fuel. Fuel must be coming up from head?? My plugs are rich so mayby i'm getting to much fuel, bad fuel reg.Its been wet with fuel for a week now it never drys up. I dont know, iam no expert. Ill need to post a picture of it i guess. Thanks
Old Sep 27, 2004 | 12:21 PM
mike L's Avatar
mike L
Thanks how about that can of throttle body spray, my guess it will only do about 50% cleaning????The local oil company uses this kit and is having been getting better fuel milage.
Old Sep 27, 2004 | 12:38 PM
ssn randy's Avatar
ssn randy
yes it could be the regulator, to much pressure. that may be why the leak near the head. leaking around the injector spraying fuel up the head toward that 1" hollow pipe. is the leak right above one of the injectors. don't know what it looks like, mine is 5.0L
Old Sep 27, 2004 | 02:17 PM
mike L's Avatar
mike L
Yes the injectors are about two inchs below the 1/4" pipes. It looks like it screws into the head, for the six cylinders. It must be part of the exhaust. The plumbing for the fuel, which is connected to the fuel regulator is a little smaller, maybe 3/16"
Old Sep 27, 2004 | 03:45 PM
  #28
mike L's Avatar
mike L
I had it towed. Cant rent a efi fuel pressure tester, and its 120.00 for the tester. Couldn't no test for codes. I asked the garage to call me back with the readings. What's the fuel pressure suppose to be at with key on not running? How about while running? If I get a good reading with key on and not running. Is that ok or do I need it to run? Thanks guys
Old Sep 28, 2004 | 07:36 AM
  #29
ssn randy's Avatar
ssn randy
should be around 40psi
Old Sep 28, 2004 | 10:58 AM
  #30
mike L's Avatar
mike L
Bad fuel regulator??
Will a bad fuel regulator always leak out of the top. With he vacuum hose pulled off?
