Temp gauge not working or t-stat stuck?
Please help! 1994 F-150 with a 4.9L I-6. The temp gauge never seems to move and I live in Texas! I'd expect to see it rise a little. It does have a lower temp-rated t-stat than the stock one (can't remember the value off-hand, but it's also only about 14 months old). I do hear something that sounds like water boiling when I shut off the engine after driving around town in the heat with the A/C on.
Temp gauge not working or t-stat stuck? What do you think?
Take the wire off the block sender (above starter) and ground it for a few secs and see if the gauge goes up if it does then the sender is bad or the t-stat is setting wide open I bet on a bad sender. If it doesn't go up when grounded then there is either a circuit problem or gauge problem.
natewoz
19
02-09-2008 11:36 PM
apropos
11-17-2004 12:10 PM
