'99 5.4 Cranks but no fuel
Hey Guys,
I hope you can help me with my 99 F250 no start problem.
Drove to the shop the other day turned the truck off and went inside. Came back out and the truck would crank but did not start.
I then started to troubleshoot. I am getting spark, but no fuel. I checked the inertia switch its ok. Gave the truck a little fuel through the throttle body and it fired right up. Check the fuel relay it seems ok. Did a few other things and now some more things are happening. When you turn the key to the on position all of the gauges sweep to max then come back down, also the theft light comes on and turns off like normal but then when I turn the key to crank the theft light comes back on ???
I appreciate your time and hope you can help out.
Ryan
Ryan
