not firing
Old Sep 18, 2004 | 07:25 AM
85brwnranger4x4's Avatar
85brwnranger4x4
not firing
i'm new to ford-trucks.com anybody tell me where to start to find out why it is not firing?it is a 1985 ranger 4x4 with 2.8 v6.it was running yesterday.
Old Sep 18, 2004 | 08:02 PM
hreed's Avatar
hreed
Had a similar problem with my 83 2.8. Turned out to be the ignition module on the distributor the first time, and the timing gears destroyed themselves the second time. Check the obvious culprits-rotor, cap, timing, coil, all the wiring etc, before replacing parts. Pull the cap and make sure the rotor is turning when you crank the engine. Keep us posted.
Old Sep 19, 2004 | 07:59 AM
85brwnranger4x4
turned out to be my coil.thanks alot hreed.
