replacing vacuum pump in the rain today
Use The Right Tools To Remove And Install The Pulley. When Putting The Pulley Back On Mine My Father In Law Hit It With A Hammer And Knocked The Guts Out The Back Of It. It Took Me A Hour To Put It Back Together. If I Remember Correctly There Was Three Bolts. There Is A Tension Pulley Near The Passanger Side Top Of All The Pulleys Use A Breaker Bar With Socket Or A Large Ratchet With Socket On It And Pull, The Belt Will Loosen Enough To Slip The Belt Off The Pulley. It Is Not Really A Hard Job It Probably Would Have Taken 20-30 Minutes If I Had Not Had To Rebuild The New Vaccume Pump. Let Me Know How It Goes.
ya no sweat!...only problem was the home made puller i made in high school was not up to the task...i consider i got off easy compared to you though...my x outlaw would have been wearing a hammer if he tried to hammer the pully back on...also now i know where my cam sensor is ...looks like a job from below...in the mean time i keep my fingers crossed
