Milemarker electric winch
Well I was all convinced that I'd go with a Milemarker 12,000 pound winch when I bought one, seeing as how they're half the price of the Warn 12K. After reading this thread on Pirate I've changed my mind. I guess you really do get what you pay for. In all fairness it seems they're talking just about the 12K, not the other models but beware!!!
http://www.pirate4x4.com/forum/showthread.php?t=283020
I plan to get a hydro winch eventually but I think my first purchase will be an electric so I can use it up front or in the back if need be. This was just kind of a wakeup call . . . I knew the MM Hydros were the shiznat but apparently their electrics aren't that great at all. Found this thread also: http://www.pirate4x4.com/forum/showthread.php?t=249602
i have the mm e 9000 and love the winch. it has a few things i would change, but then you would be paying the same price as warns. i like it because it gets me out of stucks. may not be the fastest, and sometimes you have to keep an eye on it, but it gets the job done. never had any problems with it and i get stuck alot! the cable will bind up in the drum if you are not carefull, but it's not that big of a deal. like i said, just takes a little more time. i will be getting a mm e12000 soon and putting the 9000 on the back. heres how i would think about it. if i was using my winch to pull my up the trail the whole time, i would get a warn. but if your like me and like to drive your truck most of the time and just you use the winch to get you out of the situation you thought you could make... go with the mm and do something else with the 1000 bucks you save.
hmm, kinda scarey!
i am saving up as we speak b/c i am gonna get Warns new value line winch....the Magnum 9K
http://www.warn.com/truck/winches/magnum9k.shtml
and i will buying it from here......they seem to offer the BEST price anywhere.
https://www.clemson4wheel.com/category.asp?catcode=311
now maybe i will get to use my AmSteel Blue rope
-cutts-
-cutts-
If I had it to do over again I would get a Warn, it doesn't seem like there is any other choice. The last time I got parts from U.S.Winch for my piece of crap Ramsey the guy said if I wanted a reliable Ramsey then I should have bought the 8000# they are more durable. I say save your money hold out for the Warn. Hydro's are only good if you can keep the engine running.
Ivan - I have heard some negative comments on doing the receiver winch front and rear idea. The comments that I have hear is the receiver and/or the winch tray is not up to the task especially if you get into a angle pull. What is your take on it? Most all of the manufacturers make their trays to hold up to either a 9000 or 10,000 lb winch.
I have a buddy who has used the receiver hitch winch with a 9500lb warn for over 3 years. it has pros and cons. couple of the big cons are if you get stuck in somthign thats blocking your receiver your not putting that winch on. another is your winch is typically sticking out pretty far as well as killing you approach and departure angles. luggin that winch from the front to back will get old after a while as well.
I have a 12k warn up front, I am planning on putting a 8-9500 warn under the back of the bronco. leaning towards the 8k because they are cheap and they really do not have much less pull than the 9500 which is alot more expensive. If you ****** block the 8k your pulling up to 16k. I know for what I wheel that would pull me out just fine.
i've been huntin and have decided i might just go with an 8274 that is used and rebuild it. i have found a couple for about $400 and to rebuild it would cost like $50 or less. and I already have me a brand new AmSteel Blue rope i never got to use
i would LOVE to run a MM12K lb hydro but now that i am running hydro assist i have ruled out a hydro winch
-cutts-
-cutts-
Ive been running a MM hydro all summer, I got it used, it's plumbed to its own saginaw steering pump, and i put a cooler in the return line in front of the radiator. It is slow and the cable is hard to pull out but my biggest beef is that when pulling long or heavy the winch stops. The hydro motor gets hot. It seems to help if I open the hood before I begin winching to let hot air flow on out. I dont know if the fluid is just getting too hot or maybe the motor needs rebuilt. anyone else have any opinions/ experiences ????
