my truck: bad loss of power
I have a problem with my truck and not even ford can tell me without charging me 350. When you stop and try to go again it is like watching a snail try and race. I have replaced the tps and plugs and wires ford tells me it might be a wire to my pcm and suggestions? I almost forgot to put this in here it does not give any codes ford said it tells them that there is nothing wrong with the truck
does it act the same under load{in gear} and in neutral? has the fuel filter been replaced? did you check the fuel pressure? may have fuel pump that it failing or the fuel regulator...and have you stopped the engine forums and researched this?
on edit: have you cleaned the Maf sensor? its located after the air filter, use some brake kleen or sensor safe throttle body cleaner.....
Originally Posted by scrimbaby
the fuel filter and pump have been replaced. It does not act like that in neutral
Other than that, sounds like a fuel (maybe pressure) issue. What about the plugs, wires, and such? You may need to do a SeaFoam flush.
OBTW: I just read that you have 203,000 miles on your truck! That's awesome! I like to see when a good 4.2 makes it that far...there will be plenty more to come I'm sure.
It does kinda do it in reverse but i am not going that fast in reverse. It is a automatic. How am I supposed to know if it drops all the way into 1st? If a wire was cut from the battery then wouldn't it not start? All the plugs and wires have been replaced about a week ago. What does a seafoam flush do?
See thise thread:
https://www.ford-trucks.com/forums/s...light=seafoam+
Post #15 gives step-by-step.
How would that wire just all of a sudden been damaged or whatever? It was running fine one day and then the next it was like it is now. I drive it everyday
Edited by Mod.
Joseph asks that you invest a few minutes checking the wire anyways. His was only a suggestion in an attempt to help.
Joe
