loss of power
Old 08-31-2004, 10:53 AM
super_ranger's Avatar
super_ranger
super_ranger is offline
loss of power
my friend has a 94 ranger that lost power. its a 2.3 one of the coils is dead it aint getting no power in but the coil is good. no CEL. itstarted about a month ago. just when it was cold. but then it got worse. now its all the time. between 45 and 60 its real bad. i dont think the secondary coil ever worked because its always been gutless compared to my 91 2.3. tonight im going to run a jumper wire to the b+ wire that runs to the coil and see if that does anything. but what i was wondering why it would just get gradually worse. i was thinkin fuel filter. any other ideas would be nice
Old 08-31-2004, 09:34 PM
Dealford's Avatar
Dealford
Dealford is offline
Have you checked for stored codes?
Here's a link to the Ranger board's Technical Information sticky:
https://www.ford-trucks.com/forums/s...d.php?t=107538
The 94 is EEC-IV. There's enough info there to bring you right up to speed with the system. You'll need a multimeter (VOM) to pull codes.
There's some very expert guys on the Ranger board that would be happy to help you through this problem.
AL.
Old 09-02-2004, 12:01 PM
super_ranger
the check engine light aint on so i didnt think there would be any.
Old 09-02-2004, 09:00 PM
Dealford's Avatar
Dealford
Dealford is offline
Not being an expert myself, I'm just suggesting a complete inspection. I'm sure that I've read on the Ranger forum about stored codes with no light.
If you were to post on the Ranger forum, the guys there (lots of experts) could walk you through your problem step by step. There may be answers to the problem that are not at all what a regular guy would come up with AND would solve the problem.
AL.
Old 09-09-2004, 10:14 AM
Vin 95's Avatar
Vin 95
Vin 95 is offline
The light does'nt have to be on to have stored codes. off hand I would suspect the throttle possition sonsor (TPS) when it goes bad it tells the computor(PCM) not to open the fuel injectors. They will slowly go out.
navag8ter
1983 - 2012 Ranger & B-Series
13
10-05-2013 08:07 PM
410F-100
09-18-2012 06:25 AM
sims95
02-15-2012 09:25 AM
f250d4x4
01-16-2012 06:12 PM
Kijutsu
03-13-2005 11:05 AM
Quick Reply: loss of power
