'Pop" in the front end when I accelerate
When I accelerate from a stop or slow speed I hear a "pop" in the front end. It sounds like 2 peices of thick metal popping past each other. I'm pretty sure my springs aren't broke, what else should I look at? Or is this a normal 4x4 sound?
Truck is a 95 F-150 4x4 AOD with the 5.0.
I have a similar noise in the front end of my F350. Slow startup after a stop produces a "pop" that sure sounds like something in the right front suspension coming apart. I haven't been able to find anything wrong or loose and it's been doing that for several years.
The transmission crossmember??? Well, that's something I never would have thought to look at.
Check the 1 1/8" bolt under your coil spring that retains the radius arm to the axle, then the 1 1/8" nut inside the spring which retains the spring. CLEAN YOUR SPRING then look for cracks, they can be very hard to see some times.And hey while you're at it & have the tools out go right down the line & ensure everything is tight, & bushings are good( & there!). If none of this produces for you check in the hub, 7 inspect your wheel bearings for proper adjustment.Sounds strange, but so does the cross member theory, & either one might be right!
on my 1990, I have a few of pops and clunks. I know what 2 of them are for sure. I have a radius arm bushing failing that clunks on acceleration/deceleration. and I have a front rad mount/body mount pulled through that clunks as well. I know how to fix em, but I am procrastinating.
Something to look at though.
Originally Posted by Steve91
The worn radius arm bushings are very common.
Think everything that can be stressed when you start or stop.
LinuxMercedes
11-19-2014 04:06 PM
98SurplusExpy
1999 to 2016 Super Duty
07-18-2011 09:56 PM
