'04 F150 - Aftermarket Amp with OEM HU?
I have the base stereo in an '04 F150 XLT Screw. Is it possible to install an aftermarket amp with the factory HU? Will it sound ok, or will it be noticeably inferior to an amp with an aftermarket HU? Of course, I would upgrade the speakers at the same time. Thanks.
Jon
Jon
Jon
Jon
In every upgrade i have ever done, even cheap junk was better than stock. Blows (Bose) included.
That is interesting. The only reason I'm considering keeping the stock HU is for looks - The existing HU space is very big and an aftermarket HU may look odd.
Jon
Jon
I have a standard DIN size aftermarket HU with an installation kit supplied by Crutchfield. The in-dash adapter has a little pocket above the HU, and, to me, looks very reasonable. It blends in nicely. It's certainly better than putting up with the stock HU.
If you are worried about it not "looking right" you can probably go with DIN and a half size, there's a few of them on crutchfield. You are going to want to change your stock HU to aftermarket, spend at least $120 on the HU and not from Walmart, and you should be in good shape, you get what you pay for. You should always remember, aftermaket is better than stock. Unless you're stereo had stock Boston Acoustics, then you might get about the same quality as aftermarket. Personally, I think you should upgrade HU with pre-amp outputs, and get speakers also.
I went through the same thing. Had the stock H/U, changed speakers. Not loud enough, installed After market H/U. That was O.K. for a while, not loud enough. Next week amp gets installed! It never ends. Question is that the speakers say max. 60 watts. Would an amp with 40 watts RMS be a big difference to the 22 in the A/M H/U? and how are Alpine amps.?
JonC, Be wary of broad general comments about cheap equipment being better than stock, or aftermarket being better than stock. Those comments cover a lot of territory. Everything depends on what the user wants from his system. We're talking about a few hundred dollars that can make a huge difference in the overall quality of the system. Not just sound quality, but build quality as well. The spectrum of quality in car audio is huge, and there are reasons for that. It is true that there are some "overpriced" brands, but for the most part the reasons that separate items of vastly different prices, that appear similar on the outside, all have to do with quality, both in parts and construction. Have you ever seen those guys who are ALWAYS having trouble with their system? Something is amiss constantly. There is a reason for that.
what speakers have a max of 60 watts? the amp with output at 40 watts rms is pretty good, you want to overpower your speakers with numbers, but just turn down the gain on the amp to make it sound clean, that way the amp isnt pushing all it's power.. alpine amps are pretty good, my friend had one in his focus with 1 12" kenwood, and it pushed the kenwood pretty good, i dont care for the kenwood brand though.
WB4IUY
08-20-2016 07:59 PM
High_HP
01-04-2016 06:28 AM
