New gearing in ford 8.8
I have a f-150 with the 8.8 rear end in it. I have be told that being that I am running 33" tires I should changed the gear ratio. If I am correct about this a am running 3.08. I would like to have more power and slightly better mpg if there is a way to do that. Thanks
~Offroad_guru
~Offroad_guru
yeah you can switch to 4.10s for the best performance, but that will run you around 5 or 6 hundred bucks to get them put in. i have 3.55s in mine with 33's, they arent great but i imagine that they are better than 3.08s. so if you could find your self a used one with 3.55s that would be the cheapest.
