1999 F150 flywheel teeth damaged - Ford Truck Enthusiasts Forums
Old 08-29-2004, 11:05 PM
fordguy950
fordguy950 is offline
fordguy950 is starting off with a positive reputation.
Exclamation 1999 F150 flywheel teeth damaged
I have a 1999 Ford f150 with a 4.2 engine and automatic transmission. My starter seemed to grind (sometimes) during start so I decided to change the starter. After removal of the starter I noticed that the flywheel teeth are damaged. I installed a new starter only to have the same problem (grinding) so I guess the next step is flywheel change. My question is can I buy a flywheel from local auto parts store and swap...or is it a balanced item to the engine??? I noticed in the repair manual it stated to mark the wheel for exact installation position. But I will be changing it??? Anyone have any inputs....Can I swap flywheels without a problem????
Old 09-09-2004, 10:14 PM
fplorer
fplorer is offline
fplorer is starting off with a positive reputation.
I know on older trucks you could just press on a new starter gear ring and use your same flywheel. Not sure on the 4.2, but it is something to check out. Maybe someone else knows for sure.
WilliamKG88
19
06-09-2015 03:09 PM
jimpennycuff
06-15-2007 11:49 AM
rmckenna
1997-2006 Expedition & Navigator
09-14-2006 05:30 PM
jamminmav
15
12-22-2002 11:15 PM
heybrent
1978 - 1996 Big Bronco
09-06-2001 08:55 PM
Quick Reply: 1999 F150 flywheel teeth damaged
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
