Anybody w/ a '97..... - Ford Truck Enthusiasts Forums
Old 08-29-2004, 07:54 PM
BrianA's Avatar
BrianA
BrianA is offline
BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.BrianA has a great reputation on FTE.
please check your owner's manual, or under the hood on the fan shroud, or on the oil filler cap, and let me know what the reccomended oil weight was for the '97 model year.
Thanks.
Old 08-29-2004, 09:44 PM
true4.2
true4.2 is offline
true4.2 is starting off with a positive reputation.
I don't know off hand, but I'd say the same as mine, but I'm not sure. I'd say 5W30...
Old 08-30-2004, 12:20 AM
homer4.2's Avatar
homer4.2
homer4.2 is offline
homer4.2 is new and has a neutral reputation at this point.
my 01 is reccomended 5w20..if that helpslol...should all be the same!
Old 08-30-2004, 11:43 AM
BlueOvalFitter's Avatar
BlueOvalFitter
BlueOvalFitter is offline
BlueOvalFitter is gaining momentum as a positive member of FTE.
5W30 but I run 10W30 in mine. 3 quarts of Mobil1 10W30 and 3 quarts of Chevron Supreme 10W30 dino.Its called "my blend".
Old 08-30-2004, 12:17 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
interesting BOF, I use synthetic 5w20 valovline oil now, since i hear that motorcraft is better could i switch over to 5w20 motorcraft systhetic?
Old 08-30-2004, 12:45 PM
BlueOvalFitter
Motorcraft 5W20 is a semi-synthetic oil.I mix my own to get a 50/50 of both worlds.No one knows how much synthetic oil is in a blend.They could add as little as a teaspoon and call it a blend.My way,I know what i'm getting!
But yes,you can switch to any oil you prefer.
Old 08-30-2004, 01:23 PM
BrianA's Avatar
BrianA
BrianA is offline
Old 08-30-2004, 01:54 PM
BlueOvalFitter
Brian,what is the point of that thread? I'm going to keep running 10W30 until my engne dies. I'm still confused tho.
Old 08-30-2004, 03:19 PM
BrianA's Avatar
BrianA
BrianA is offline
Discussion.
A few different points of view and we're all just bouncing our ideas off each other.
Old 08-30-2004, 03:24 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
"we're all just bouncing our ideas off each other." - Brian
Yea, i didn't even get what I wanted from that conversation really....it was basically like, "do what you want, anything works!"
Old 08-30-2004, 03:30 PM
Off Road Ron's Avatar
Off Road Ron
Off Road Ron is offline
Off Road Ron is starting off with a positive reputation.
my 1997 manual says 5W30
Old 08-30-2004, 03:42 PM
true4.2
true4.2 is offline
Heh, I figured it was 5W30...I'm the man....woot........woot..........woooooooooooooooo oot....
Joe
Old 08-30-2004, 05:44 PM
99F150
99F150 is offline
99F150 is starting off with a positive reputation.
5W30 was recomended untill mid 2001. My dad has a 2001 Super crew built in May 2000 and still calls for 5W30. I believe trucks built after the changeover to the offical 2001 all call for 5W20
Old 08-30-2004, 07:15 PM
stakelinfocus
stakelinfocus is offline
stakelinfocus is starting off with a positive reputation.
Thanks.
5w30 used to have one
Old 08-30-2004, 09:59 PM
homer4.2's Avatar
homer4.2
homer4.2 is offline
yes, my 2001 reccomends 5w20. Not sure on the build date, I'll check into that tomorrow.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
