Buying a diesel pickup - need a guide - buyers guide - prepurchase - What to Look for
I searched and didn't find anything like a buyers guide or a prepurchase check list. I need help, can someone point me to some search terms or threads along these lines. Thanks in advance for your help.
What should I be looking for?
Today I looked at a 1986 F250 6.9 C6
Looked for oil and stopleak in the coolant - found none
no pressure in radiator - didn't warm it up
Looked for water in the oil - found none
Trans fluid dirty but not smelly
Cranked without glow plugs - didn't start
Started quickly with glow plugs
little smoke from exhaust or crankcase
Good points: new tires and batteries, it runs and drives
Bad points: It is a beater, basically good for a work truck and/or parts truck
Coolant is rusty colored.
Napa wanted $23 for a coolant test kit to test for Nitrides? It mentioned the additives DCA4 or SCA, is this what I want and is it available cheaper?
Check out this link to a coolant test using a voltmeter:
http://www.napaechlin.com/tmt23.htm
I have searched enough to decide that the truck I want to buy is an idi turbo. I would be happy with either a factory turbo or an aftermarket. I would have to research the aftermarket installation to be comfortable buying one that is properly installed and not just a hack job.
I am not in a hurry to buy a truck, I can take my time, I am just starting to look. Would it be worth it to buy the beater I mentioned above to learn on, use for a work truck and later for a parts truck? Would enough of the parts interchange to make useful as a parts truck?
Inherent weakness in head gasket on idi engine
Good thread on coolant additive and cavitation
Thread recommends coolant test and compression check - good info on compression check
Glow plug thread
Glow plug thread
What to look for
cavitation???
Searches for 'purchase' are turning up more results.
6.9/7.3 Diesel Questions:
sca test strips...7.3IDI non-turbo...
cavitation???
Here a couple links to articles over at the Diesel Stop:
Buying a Used Ford Diesel
Buying a Used Ford Diesel II
