Motor interchangeability?
Old Aug 28, 2004 | 04:45 PM
don_79f250's Avatar
don_79f250
Gentlemen,
Well, I've found an engine to replace my poor destroyed 351m, (spun a rod bearing and chewed a 1/16" gouge into the crank) and I just want to double check interchangeability.
Right now I've got a '79 F250, 2 wheel-drive, with a stock 351m and auto tranny.
I've found another F250 with a 351 in it, but that's all I know about it. Found it over the phone, and the guy (who I know and trust to sell me a good working motor) didn't have all the details. The donor truck is a 5-ton moving van with a 4-speed manual.
Question: I've been told that pretty much all Ford 351's are interchangeable - same motor mounts, same bolt bell housing bolt pattern regardless of type of tranny.... is this so? Or do I have to check out this engine more carefully before committing to it?
Thanks.
Old Aug 28, 2004 | 04:48 PM
ford390gashog's Avatar
ford390gashog
there are 3 types not all interchange the windsor,cleveland,modified
Old Aug 28, 2004 | 05:32 PM
alcan60283's Avatar
alcan60283
As long as it's another 351M or a 400 you're alright. 351C,351W,302,289,300 all have the small block bolt pattern. 429 and 460 also share the same bolt pattern as the 351m and 400. Those are you're choices for engines. As far as the one in the F250, as long as the truck is from the 70's its most likely a 351M. Altough, it could be a 352 FE. Those were also offered although, the 390FE is more common. IF you need any more info, just let us know.
Edit: Might wanna stay away from a motor out of heavy trucks like that. They've probably been beat and also have probably had less than normal service schedules.
Old Aug 28, 2004 | 06:43 PM
fellro86's Avatar
fellro86
I didn't think the 352 made it out of the 60's but up to 76 can be a 360, or 390, as far as the FE's go. If it is a 70's truck, I don't think they put windsors in yet, did they? Also being that heavy a chassis, they would be likely different, as the FE's were 361, 391, and would be a real PITA to change to. You're gonna want to get a look and compare before you agreee to it. I can't believe they would put a Windsor into a 5 ton, never seen it, and actually, hope I don't. Can you imagine the dog that would be? It about would have to be an M, if it truthfully is a 351.
Old Aug 28, 2004 | 07:34 PM
ford390gashog
yeah no 352 in the 70's just 360 and 390 until 76
Old Aug 28, 2004 | 07:41 PM
ranger429's Avatar
ranger429
Just ask the guy how many valve cover bolt's there are, 6 or 8. 6=351W 8=351M
If it is a 351 it is going to be a 78 or later
Old Aug 28, 2004 | 09:37 PM
don_79f250's Avatar
don_79f250
Apparently - again, this is guys I know telling me this so I'm going on the assumption this is no B.S. - the engine had just had a $3,000 rebuild (that's parts & labour) when the truck had an accident and was written off.
Thanks all for the info - I'll check it out.
Old Aug 29, 2004 | 02:45 PM
Purely Ford's Avatar
Purely Ford
Don't assume it can or can't be any 351. As old as these trucks are, they have had many owners by now and could have had plenty of engines swapped into them. Look at the engine first hand and determine what it is.
For instance, I have a 428 in my F100 and Ford never put these in a truck like mine. I have seen 351Cs and 429s in trucks like these and some other brands, but they weren't suppose to be there. Don't take the word of anyone you don't know and trust when it comes to what engine is in any truck. If you make someone angry when you insist on identifying the engine in a truck they want to sell, then you should look even harder and closer or just walk away.
Old Aug 29, 2004 | 07:02 PM
73F250Ranger's Avatar
73F250Ranger
[Originally Posted by don_79f250]
Since you know the guy, maybe he can get you the paperwork from the engine rebuild shop. That would not only solve the engine history mystery, it would let you know exactly what was done to the engine during rebuild.
