small ports on my 390 Performer intake.?
Just got my performer intake, along with my Edel. 600 vac. seac. carb.
Noticed that the intake runners are much smaller than the intake runners on my heads. Has everyone else had this? Should I flare out the ports to match the I.D. of my heads or leave them as is?
Thanks, Robert P.
Thanks, Robert P.
Big port/little port
I_THNK_FORD, yes the intake ports are smaller than the heads but the intake will have a higher velocity fuel mix off idle. How you going to use the truck, work, street race, drag race? What type trans, rear gear ratio and cam? With the small ports thru the intake runners little will be gained by flairing out to the heads. This may do more harm than good as well as lowering resale value. The RPM series will wake it up with little off idle loss. $.02. Carl.......o&o>.......
Thank you both. " Don't fix what ain't broke."
Daily driver&work truck/3.73/
Melling
Dur. @ .050: 204 Int / 214 Exh
Adv Dur.: 282 Int / 292 Exh
Cam Lift: .281 Int / .296 Exh
Gross Valve Lift: .486 Int / .512 Exh
Center Line: 104 Int / 120 Exh
/headers/t-18.
Thanks for your input.
Robert P.
Melling
/headers/t-18.
Robert P.
baldboyford
03-14-2009 02:25 PM
LedheadELH
35
11-01-2006 06:52 PM
FEmtnmax
11-10-2005 05:32 AM
