'99 Explorer idle trouble
Just wanted to check if the problem I am having with my '99 explorer 4.0 sohc sounds like a TPS problem or not. On occasion when first starting , will not idle and dies. Will run if gas is given. Seems to go away after vehicle is run for a while. Runs absolutely fine besides wanting to die seemingly due to idle control. I suspect the TPS, but have never had this trouble on a Ford before and wanted to see what you might think. Thanks
I had the same problem last week with the same engine, I disconnected the MAP sensor plug on the drivers side of the engine for about one minute while maintaining 2000 RPM after the engine was warm and the problem went away.
I don't know why but it worked...so far.
Good Luck
Good Luck
86stepsideF150
10-07-2009 02:55 PM
funzjb1
03-12-2006 08:55 PM
