85 I6 300 carb problems...
Old Aug 23, 2004 | 01:24 AM
Joe_C's Avatar
Joe_C
Hey
i have a 1985 F150 300
i have rebuilt the carb re installed it truck starts and idles great but it stumbles and chugs when ya hit the gas hard it will rev fine if ya gently roll into it
i have adjusted the mixture screw?? till it runs nice and smoth and pulls 21" vacume with a fairly steady needlle (jumps about a 1/4" (of vacume) fairly rapidly (about 1/16" needle movement on the gauge)
any ideas whats up?
thanks
Joe
oh its a canadian truck with no polution stuff (factory setup)
Old Aug 23, 2004 | 01:55 AM
Ford_Six's Avatar
Ford_Six
It sounds like a timing issue- what is it set at?
Old Aug 23, 2004 | 12:08 PM
Joe_C's Avatar
Joe_C
as far as im aware its where ever ford put it
i will see if i can find a light and check it do i need to unplug the vacume advance?
thanks
Joe
Old Aug 23, 2004 | 03:57 PM
holland501's Avatar
holland501
If it pops back through the carb then it is too lean. Since it idles ok, I would look to the acceleration pump adjustment. Increase the stroke a little and things should improve. keep going until it accelerates without missing. Good luck.
Old Aug 23, 2004 | 04:55 PM
Joe_C's Avatar
Joe_C
thanks for the thoughts
Joe
