Pictures of Atlas II & KluneV installed in rig
Thanks all
Lets see. How low do we really want to go? Kinda stuck on really slug. The Atlas low is 3.8 low and the Klune is 2.7 low. Plus both the diffs have 4.56 gears and ARB's front & Rear.
It's nice having 4 different ratios to choose from while in 4x4 = high range or 2.7 or 3.8 or combined for 6.5 Way too cool. I almost went for the 5.0 low range Atlas, but I Probably would not have gotten it until now. Too long of a wait.
BTW - I ended up decentegrading my rear end, cause of this setup. The diff carrier split in half along with the spider gears in hand fulls of pieces. And of all the places for this to happen in my own driveway. This happened the day before I was going to go to Hollister Hills with a bunch of other Bronco owners for on off road trip.
thats darn low ratio crawl!!!
Are your truck rock crawling?
I used to own 2000 wrangler with heavy mods and was doing it for fun rock crawling!!! but i sold it cuz of few reasons...
Thats how i got me new f150 2004 FX4.
ANy pix of your rig ?
Heres mine. this pix was taken at Paragon in PA and was on Pick Your Poison trail its fun!!!
YOMAN!
YOMAN!
Originally Posted by rlh
Tite,
Where do you park it at night?
Also, I wanted to say that I just finally received my 35 spline ARB for the Dana 44 front end. I have spare housing that I'm getting cleaned up to install the ARB & new gears(4.56). Haven't been able to go wheeling since I grenaded my rear and rebuilt it with the new gears. Can't wait!!!
Originally Posted by tite4x4
HA HA HA HA I about died. Had to wait about a half hour before I could compose myself to reply.
You relatively safe from me. I moved from the Inland Empire to the Florida Hill country. Where did you get the 35 spline ARB?
Hey Jopey,
As soon as I get my spare front pumpkin built with the new 35 spline ARB and axles and then put into the Bronco then I will try and get some pictures taken when a take it out wheeling to break it in. I can't wait!!!
Which Dana 60 knuckles, axles etc. are you going to use? I'm considering putting that set up in a cut & bent ttb housings with reinforcing gussets. That would be 4" + of lift without the need for dropped axle pivot brackets, Dana 60 axles and hubs, and a stronger carrier which happens to be selectable. Its going to be interesting to see if this will work in a ttb.
Originally Posted by jopey
so your around 140:1 for about 5 grand
I am 137:1 for under 1 grand with a 203/205 doubler.
but none the less if I had the cash to blow I would have done it as well. So post up some bronco pics.
ckrichard
06-29-2004 08:56 AM
