installing neons/LEDs and blowing fuses
I'm currently in the middle of puttin a couple neon tubes and some LED's in my expedition. When i ended for the night the other night i had two tubes, and one led hooked up that worked fine. In my setup i have a couple of 8 position barrier strips and a swtch with an LED in it. I have a wire goin from battery to switch, out the switch and to one of the barrier strips. I have teh other barrier strip grounded and the swtich ground ran to that strip. I've ran some more wires over the past couple nights but haven't hooked anything else up yet. Today I'm blowing fuses all of a sudden. If i have everything disconnected except the switch, the led on the switch lights up and no blown fuses. But, if i hook ANYTHING up to the barrier strips the fuse blows instantly. I'm at a loss as to what could have changed from the other night to today why i'm blowin fuses all of a sudden. Any suggestions?
