Hydraulic Clutch Problem
Old Oct 4, 2000 | 05:48 PM
hlgilliam's Avatar
hlgilliam
Hi! I have a 93 Explorer and I just had the clutch replaced. I am still having difficulty getting the clutch into first and second gear...anyone have a clue as to what it is? I already took it back once and it still does it.
Thanks!
Old Oct 4, 2000 | 10:35 PM
PAUL_2's Avatar
PAUL_2
What was replaced during the clutch work ? Lots of possibilities , Need to know exactly what was done before a possible remedy can be suggested .
Old Oct 5, 2000 | 08:33 PM
hlgilliam's Avatar
hlgilliam
Hi!
Well, I am not sure exactly what was replaced but it is my understanding that "it all" was replaced. I do know that the slave cylinder was replaced. I was having the problem when the clutch was getting ready to go out if that makes a difference. It is only first and second gear that are giving me so much grief.
Any help is SO appreciated!
Old Oct 5, 2000 | 11:02 PM
PAUL_2's Avatar
PAUL_2
Its possible the system was not bled properly ? What transmission is in your Explorer ? Any noises from it ?
Old Oct 5, 2000 | 11:07 PM
hlgilliam's Avatar
hlgilliam
*Supposedly* they bled it properly because I took it back once. The problem is, it isn't hard to switch gears ALL the time. It is a 4WD. To be honest, I am not sure if I could identify a transmission noise. I seriously hope the transmission isn't going!!!! The fluid level was okay on the transmission when they checked it, though they did say the fluid looked very 'burnt'. (This, however, is probably because it hadn't been changed in an eon.)
I just don't know what is going on!
Thanks!
Old Oct 6, 2000 | 04:35 PM
latko's Avatar
latko
banks0531
Jul 10, 2016 02:07 PM
HunterSThompson
Feb 28, 2015 01:33 PM
Visseroth
Apr 28, 2013 07:29 PM
keyes
May 7, 2008 08:19 PM
1987fi50
Nov 22, 2005 02:19 PM
