Towing questions...
Old Aug 19, 2004 | 05:35 PM
Blasphemous's Avatar
Blasphemous
Towing questions...
In 2-3 weeks I'm making a 1200 mile, one-way, drive (moving) from NY to MO. What all should I do to prep my truck? It's a 1984 F150 w/ the 300 I6, Auto tranny (code-W) and a 3.08 rear.
So far this is what I have... EFI exhaust manifold, Walker downpipe, One-chamber muffler on a 2.5" exhaust. Intake will be a stock intake w/ a Holley 350cfm carb on top. The radiator is getting an electric fan and custom shroud. I also have a 20kGVW transmission cooler.
I'm going to be towing a 68 Oldsmobile Cutlass (no engine) on a dolly. In the bed I'll have all my tools and tool boxes (about 200lbs worth), 3 engines (one big block, two small blocks... enough parts to make two complete engines) and all of my personal belongings and spare car parts. The bed will have about 1500lbs in it, the car weighs about 3000lbs empty.
I'm not looking to set any land speed records, just want to chug along at about 60mph to stay out of the way.
Old Aug 20, 2004 | 06:08 AM
Blasphemous
Noone can help or I've got it all covered?
Old Aug 20, 2004 | 06:17 AM
MKB's Avatar
MKB
I am not sure what the weight would total on the engines, but personally I think you will have some problems maintaining speed. That seems like a lot of weight. I have a 1986 F-150 with the I6. I towed my camper which weighs about 4,000 and it struggled a bit. I retired it to pleasure driving and bought the 04 F-150, what a beast. I wish you good luck though. Maybe with the modifications you have you will be O.K.Mike
Old Aug 21, 2004 | 04:51 AM
63redtudor's Avatar
63redtudor
I also have an '84 F150, but its a 4x4, 4spd, 3.55 rear. Also, I'm running a autolite 2100, offy "C" intake, EFI exhast. Over the last winter I moved from Oregon to Colorado (Wyoming SUCKS in the winter). I was able to make great time, though I didn't set any speed records. I first pulled a car trailer with a falcon & then a loaded trailer, both times the truck was loaded down pretty good (probably overloaded, oops). I moved the last stuff (once again towing a falcon & loaded the truck) over about a month ago with a Uhaul F350 with a 460/auto. To tell you the truth, the 300 did better than the 460 on the hills, got better gas milage to boot. As for you, that 3.08 rear isn't really going to help you out all that much, but you'll probably make it just fine.
Old Aug 21, 2004 | 09:16 AM
broncr's Avatar
broncr
One thing I didn't see, which helped me a BUNCH when towing, is AIR SHOCKS on the rear. It cut WAY down on the "Tail Wagging the Dog" syndrome.
I got a pair at NAPA - for about $100.
Old Aug 21, 2004 | 10:54 AM
5_labsownus's Avatar
5_labsownus
Well, it looks like you have everything covered. When you add the electric fan, make sure you drive and adjust the thermocouple. I have an 82 I6 (see signature) and pulled about 3 tons for 250 miles over mountains. As you know, with a load up-hill is slow and the temp will rise but it should not overheat (my truck did not). On low grades you should not have any problems with speed. I could maintain 65-70 mph. Make sure to check the all fliuds before the trip and re-torque the intake/exhaust bolts. If you don't have trailer brakes I would suggest them. It was wortk the cost when pulling more than a ton. I even found they were a plus on the pop-up camper when I pulled it with the truck.
A Note on the fan:
If the thermocouple pushes into the radiator, make sure the fan sits as low on the radiator as possible. The fluid level should be as high as possible and the thermocouple should be down no more than an inch of the water inlet and as far away from the fan as possible. When pulling I set the thermocouple lower and make it kick on prematurely!
Old Aug 21, 2004 | 06:01 PM
Blasphemous
Thanks for the tip(s). I think I'll be hitting some small mountains on my trip. Shouldn't be to much of a problem though.
Old Aug 21, 2004 | 07:36 PM
woodman209's Avatar
woodman209
I-6 Is a torque monster if on big hills 1st gear low will get you there
Old Aug 23, 2004 | 12:37 PM
83Van's Avatar
83Van
You should be OK long as your butt doesn't drag too low from all the weight :-) Seriously... your main limiting factor is going to be that 3.08 rear. You'll be fine in the flats, but may slow to a crawl going uphill.
I'm about to tow ~4000 lbs of stuff and trailer on a 5000 mile round trip for the third time. First two trips with the stock 3.00 rear meant 25-30mph going uphill. Not fun when you're crossing the Rockies. Just finished installing a 3.50 gear over the weekend, and I can notice a big improvement in how she pulls.
Old Aug 23, 2004 | 01:43 PM
Blasphemous
I might get those gears then, I'm still thinking about it. My rear main seal is bad, so I have to get that done first.
Old Aug 23, 2004 | 04:13 PM
Jaster's Avatar
Jaster
Should keep up atleast 45mph, I can pull my fathers suburban around without much trouble(Iearned that today...)
