Sponsored by: Kumho
Need Help!
Old Aug 19, 2004 | 03:52 PM
SPOOLINGHOST's Avatar
SPOOLINGHOST
Need Help!
I HAVE A 97 F350 CREWCAB LONGBED 4X4. I WANT TO LIFT IT. I WOULD LIKE TO CLEAR 38' SUPER SWAMPER TSL RADIALS. I FIGURED A 8INCH LIFT. I CANT FIND ONE! HELP ME OUT. I WILL GO 10!
Old Aug 19, 2004 | 09:42 PM
95soontobelifted's Avatar
95soontobelifted
8" of lift should definately clear 38s. You may even be able tyo slip by with 6". I used a place called Rockey Mountain Suspension online to order my lift. I'm sure they have one that will fit your application.
Old Aug 20, 2004 | 01:45 PM
bronco5.8's Avatar
bronco5.8
If they have a 6 inch lift you can also raise the body 2 inches and there's your 8 inches. Good luck.
Warr
Old Aug 20, 2004 | 02:29 PM
SPOOLINGHOST
The biggest i found was a 6 inch. i wonder if the 38's would rub with the bushwackers. I also hear that you shouldnt put a body lift on Power strokes due to it not getting the right cooling? is that true
