#1 cylinder
Old 09-11-2004, 10:38 AM
spiked's Avatar
spiked
spiked is offline
#1 cylinder
i need to know what piston is the #1 cylinder so i can time it on a 1968 534 in a T850 dump truck i just purchased ?? it has all new ignition and it runs like it is laboring all the time?? also need to know what the timing specs are ???
any help would be greatly appreciated !!!
Old 09-11-2004, 05:04 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,592 Likes on 1,297 Posts
Driver side front is my guess. Look on the runners of the intake manifold...sometimes the numbers are cast on those.
If you go off the Driver side front vs. pass side front, your timing light should tell you if you are close, and then you can adjust from there.
Old 09-13-2004, 01:01 AM
f250rangerexplorer's Avatar
f250rangerexplorer
f250rangerexplorer is offline
i always thought on v-8's that they were as looking towards the rear.
1-3-5-7 Pass Side
Intake
2-4-6-8 Driver Side
Maybe i'm wrong but just my $0.02
1978 F-250 Ranger Explorer 4x4
351M, C6, Np205, D44, D60 4.10LS
Drive It Like You Stole It!!!
Old 09-21-2004, 10:45 PM
Birken Vogt's Avatar
Birken Vogt
Birken Vogt is offline
I had one heck of a time re-ordering the wires on one that someone had screwed up the order on, I could not for the life of me figure out the cylinder numbering. I had to take off the valve covers and take out the spark plugs and put bits of solder in the holes and then have someone bump the starter so I could see which order things were working in. This is what I came up with:
Code:
Driver    Passenger
The reason I had such a hard time with it was that I had always been taught that the forward most cylinder was number 1, not so in this case.
Birken
Old 09-22-2004, 03:14 AM
pfogle's Avatar
pfogle
pfogle is offline
#1 should be the front passenger side....
Old 09-22-2004, 09:47 AM
spiked's Avatar
spiked
spiked is offline
thanks for all the help !!!!
BroncoBilt
1978 - 1996 Big Bronco
01-09-2015 12:01 PM
obscurity
05-21-2013 08:49 PM
neurodancer
06-12-2006 01:15 AM
wolfmanagh
07-13-2005 08:56 PM
Katmandu
22
07-12-2004 08:34 AM
Quick Reply: #1 cylinder
