Shock absorber mounting bolt for 1994 Explorer
Old 04-30-2001, 10:32 AM
msams's Avatar
msams
msams is offline
Hello All,
I was trying to do a simple replacement of the front shocks in my Explorer Sport 4X4 when the retaining nut for the bottom mounting took off the tip of the mounting bolt. Of course this had to be on a Sunday.
Would you have any suggestions of my next course of action? Is this bolt welded to the axle/frame?
Thanks,
Mike
Old 05-11-2001, 02:33 AM
brianb9's Avatar
brianb9
brianb9 is offline
It is actually pretty easy to fix this problem. The bolt is welded onto the radius arm so you need to grind off what is left until it is smooth. Then go to your local auto parts or 4 wheel drive store and buy a replacement stud that is threaded on both ends with what looks like a large nut in the middle. Drill a hole where the old bolt was and bolt the stud through the radius arm using the end with finer threads and the supplied washer and nut. Then your shock will have a bulletproof anchor to bolt to that will not break again. The part should only cost $5.00 or $6.00.
Old 05-11-2001, 10:56 AM
msams's Avatar
msams
msams is offline
Brian,
Thanks,
That's what I ended up doing. Still, its a silly design on Ford's part.
Mike
Old 05-12-2001, 04:48 AM
cubster's Avatar
cubster
cubster is offline
1950FordF1
02-16-2016 02:09 PM
FordOwnerJoey
10-13-2015 05:52 AM
kabur66
6.7L Power Stroke Diesel
09-19-2013 06:29 AM
mikeonetray13
29
08-04-2013 01:50 AM
jamie7375
1999 to 2016 Super Duty
12-10-2008 02:38 PM
Quick Reply: Shock absorber mounting bolt for 1994 Explorer
