Speed dependent vibration
Old Aug 9, 2004 | 04:10 PM
garyh888's Avatar
garyh888
I recently developed a large bouncing vibration on the front end of my 1976 F-150. It started out of the blue while I was driving around. When I reached 30 mph it started bouncing and stopped once I reached 40 mph and higher. It seems like it would get worse as I picked up speed if it was a wheel out of balance. Could this be a case of a broken shock?
Thanks
Old Aug 9, 2004 | 04:50 PM
jpdmoe's Avatar
jpdmoe
i had the same problem once on my truck and it turned out that the front tires had wear bars. it had wore down that they stuck up about a half inch. rotate the tires smoked em good and hard and its been fine ever since. dont know if this will help or not.
Old Aug 9, 2004 | 05:53 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sometimes a wheel will throw a weight and start to vibrate. Your shocks normally help to control vibrations so a weak or broken shock can make the problem worse.
Old Aug 10, 2004 | 05:47 PM
LilDuke's Avatar
LilDuke
I actually saw a ford escort going down the highway at 80Mph and the driverside rear tire was bouncing like a basketball. I agree with Tourqe1st, balance the tires and put new shocks on. -Dave
Old Aug 11, 2004 | 08:47 AM
73Custom's Avatar
73Custom
Just to be sure, rotate the front tires to the back and test drive. If the vibe moves to the rear, then you are SURE it's a tire...
Marty
