F150 or F250??
F150 or F250??
I'm looking for a 76-79 Ford with 4 wheel drive. i'm leaning toward the 76-77 cuz I really want an FE engine and I like the front end........the reason I'm not looking earlier than that is because I'm shootin' for an NP205 transfer case. My question is this. For what I'm lookin' for, a good 4wd work/huntin truck. Do you recommend the F150? or the F250? Besides weight(axles, etc) and front suspension, are there any other real big differences? Any opinions will be awesome. Thanks
I recommend the 150. Most of the parts are the same as the 250, but you will get the coil spring ride, which I think rides better. Plus, if you aren't going to put 38s on it, they will be fine. Just driving around with the occasional work won't hurt it. Back then they were rated pretty high for a 1/2 ton. If you plan to work it regularly, buy the 250. You get better brakes, and a stronger susp. so you can carry more. Also, the 250 axles are usually lower geared, making them ideal for tire upgrades. Ted
It's a direct swap to put a 390 in place of a 360, and its pretty easy to convert a 360 to a 390, so I wouldn't be to scared about a truck that actually has a 390 in it. Remember that all of these beasts are getting near 30 years old and have probably been rebuilt at some time or another. Remember too that sometimes a 360 magically becomes a 390 when people go to sell their trucks, as there's no real way to tell except by measuring the stroke with a dowel.
BTW - the NP 205 transfer case can be found in the '73 - '75 F250's, so I wouldn't rule them out because of that. The only real drawback to the older trucks is the closed-knuckle D44-6CF front axle w/drum brakes and outdated power-assist steering setup.
If the disc brakes are an issue and you gotta have an FE, then you're talking about a '76.
it sure is funny when they sell a truck with a 352 or 360 it right away changes into a 390 or a 410
blue76
04-17-2007 12:17 PM
mustangguy732
10-13-2004 07:52 PM
